RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 02-05-2009 | 01:53 PM
  #824
crazyf3a's Avatar
crazyf3a
Default RE: Composite-ARF Integral, kinda build thread
Hi to All
The stab of my Integral had a difference of 0.5 deg. So I had to do something. Not the first time, I'm not the only. I know all know about the errors or the quality of the kit. I want nothing to say more about this. An old saying says: Speech is silver, silence is golden. For any builders Helps or Tipps. I have built stab adjustors. So I made it.
First, I carefully drilled the Carbon bolt out from the stab. Then I took my Dremel. Next step, I fitted plywood 2,5 mm and and adjusted everything. The last step i make Plywood 2,0 mm filling. So that the adjustor has fit exactly. Here are some photos about the work. The stab now I can adjust exactly. The next step is to take wing adjustors. But this is other story.
ID:	1128147   Click image for larger version
ID:	1128148   Click image for larger version
ID:	1128149   Click image for larger version
ID:	1128150   Click image for larger version
ID:	1128151   Click image for larger version
ID:	1128152   Click image for larger version
