RE: HANGAR 9 CARDEN YAK G-62
I have a 30% SD Yak with a G62. It certainly has the power, but it required 2 3000 MAH as far back in the cockpit as I could get them to get the CG close. So it is a fat pig, just under 20 lbs. I had a Quadra 50 in it and it was a real dog. Before that i started out with a fuji 50 in it, and i could never get that motor to run worth a dam. The next one I build assuming that sooner or later it will meat its demise, Im going with the DL 50.
