ORIGINAL: bdelmonte
checked the wiring to the main motor and tested it to measure zero resistance with a digital multi-meter, as desired.
I welcome all suggestions here.
I don't think you want the resistance to be zero. I just checked my motors and found the N60 motor to have a resistance of 20 ohms and the GWS motor to have 4 ohms. The GWS motor is mounted and has the full length of wire soldered to it. Either way, its not zero.
