ORIGINAL: yel914
I've tried the router table method but had mixed results. The balsa didn't trim as clean as I thought it would. I did have great results though using a sanding drum with a bearing mounted on top, mounted in my router table set at low rpm.
Nice idea, yel914.
Did you make the sanding drum/top bearing or is it available on the market? Don't believe I seen one.
This combination would give you lots of flexability and make quick work of duplicating parts.
