RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 02-07-2009 | 04:46 PM
  #826
geoflys
Default RE: Composite-ARF Integral, kinda build thread
I have a question guys about the phenolic control horn installations....because the pivot point is on the top edge of the control surface..does this mean that the phenolic control horn should be mounted in such a way that it is not exactly over the hinge line(as veiwed on the bottom side of wing or elev)...for it appears to me that the seam between the aileron and wing is in a slightly different position ...(top and bottom) so,perhaps a 2mm rearward offset of the contol horn fixation point...would be correct...??? or am I just out of my mind???
just go with the seam???
