RE: how do you spray carbon fiber on your car
It is possible to use spray paint to immatate CF. I've done it for a couple of things. You use a silver paint and a dark gray or black paint and the waffle looking non slip shelf liner. Spray on a base coat of silver, let it dry, lay the waffle liner over the area and spray the black on. If you use an air brush you can mix your own colors a bit to get the look you want. With a little practice it can look pretty good.
