how do you spray carbon fiber on your car
i burnt a hole in my body cit \nd was thinking of buying a new 1 how do you spray carbon fiber
GA
RE: how do you spray carbon fiber on your car
It is possible to use spray paint to immatate CF. I've done it for a couple of things. You use a silver paint and a dark gray or black paint and the waffle looking non slip shelf liner. Spray on a base coat of silver, let it dry, lay the waffle liner over the area and spray the black on. If you use an air brush you can mix your own colors a bit to get the look you want. With a little practice it can look pretty good.
WI
When I spray a carbon effect, I lay down transparent black first, then whatever color I wan to tuse, then back it in black. The transparent black first coat adds some sheen and depth, to make it look more real.
I dont know why you want to spray CF on, the CF nanaotubes would not be uniformly aligned, and thus thet cannot exhibit their superior tensile porperties.
Speaking of CF, I will be thoroghly impressed when long continuous CF nanotube threads can be made and woven in a nano-loom to creat CF fabrics, and then laid out and laqured to make superior CR RC parts.
Imagine a spray can that sprays out continuous CF nanotubes out of a can! Talk about silly string!
