RE: Mini Titan thread
Thought I'd post where I'm at in my build. I still like getting the ESC & servos. I got my blades balanced perfect but have a slight problem. It seems that one of the root ends are bigger than the other and when you put the blades on one is very tight to the point to where when you tighten the bolt you can see the blade grip bend. What would be a good set of blades to go with?? I'm also (I think) having a problem with the tail blades also. I'm not sure if they shoud be this way or not but when you look at the blades from behind they both curve towards the boom like they are warped?? anyone have this problem? You cant tell from the pics but I've replaced all the phillips head screws with hex head ones from hexcrews.com and I can tell you its worth the time cost $14.00 and that includes the shipping charge, decals, and extra screws. I think they fit and look much better the stock ones.
