checking incidence angles
Hi, i would like know the best way to check and adjust incidence angles on our giants.
the theory is quite simple but the method is a little trickier!
What i am after is how others set up the plane and stabilize it on the bench, how to stop the flexing in parts with the weight of the gauge on it, do you set everything to a wing that you leveled first?
As you can see, i would like to learn how others are doing it to get the best resaults possile, also the easiest way possible.
I hope others can chime in with there great ideas!
Oh BTW, i have a comp arf extra 330l 2.6m that needs some checking, and the canopy frame is curved which makes it hard to establish a level point!
