RE: slayer problem!!! need help!!!!
Well at least you found that the spring and shoes were broken, was going to let you know thats what happened to mine also. Mine also had the same problem for it not starting. What it turned out to be was the blue wire for the glow plug was bad so I just started using a glow ignitor untill I got around to replacing the wire. Hope this helps you.
