RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 02-10-2009 | 01:00 AM
  #3719
dan4466's Avatar
dan4466
My Feedback: (68)
Default RE: DL-50 engine
ORIGINAL: Tired Old Man
You guys make engine mounting much too difficult and expensive. Picture below of cheap and easy standoffs that are a lot better than metal ones having tiny little feet. If you need a box to stiffen up the firewall because the engine torques too much then simply add 1/8" ply to the outside of the wood standoffs, turning them into a box. I've used them from 28CC up to 115cc so far. Years of use and never a problem. That's 3/4" square poplar available at most hardware stores. Each of those legs is good for a few tons of pressure.
For gas filters just run on down to the local lawn and garden or saw shop and pick up 2 of the filtered clunks in the picture. One is the gas tank and the other in the gas can. They are heavy enough to keep the pick up in the fuel. The felt breaks up air bubbles and picks up every last drop of gas in the tank. yes, they are a bit large and they will fit through the opening of every gas tank I've seen so far.
That would be a good option with the square hardwood standoffs, but I need them 2" and that means I am gonna need at least a 2 1/2 bolt and I cant find any over 2" long anywhere around here in 10-32. I can get 2 1/2" 1/4-20's everywhere, but that'll add a lot of weight to a plane that was already nose heavy with the Moki 2.10 I had in it. Thats why I think I'll go with the aluminum ones. Thanks, TOM on the tip for the fuel filter. I'm gonna pick up a couple of those.
