RE: Will it work?
Yeah I'm good to go. Oil in the filter and everything works fine. The radio box is sealed pretty good. I got some puddy covering the hole in the bottom where the servo wires come through and the top is pretty tight. I run the car in the back yard. Since it was warm enough yesterday the snow melted and the back yard was a little muddy. Hahaha I use a hose and run water over it lightly then blow if off with a air compressor. The water doesn't hurt anything, like I said I take my time cleaning her off. I'm going to order the mud guards and trim them down for a better fit. I'm sure that'll keep everything from splashing inside. I'll post some pics once I get done. Thanks guys. Joe
