RCU Forums - View Single Post - Help with Extra 300S
Old 02-10-2009 | 09:23 PM
flystright's Avatar
flystright
My Feedback: (13)
Default Help with Extra 300S
Hi, Found a home for my Super Tigre G90, (Extra 300s 60-Turquoise)Found a lot of post on this plane, but not with the G90. Was reading a review on the G90 and I would like to know which setup would work best for this plane. Also would like to know. What is the best way to set up the servos? I have read post where the servos are set up in different ways, 2 elv servos with non-rev-y harness and 1 elv servo with the 2 pushrods tied together to 1 servo,ect. Servo size, battery size and voltage and prop size. If there are other setups that will work great with the G90 on this plane I would be very interested in reading.
Working in NJ this week will be finishing the F6F Hellcat 60 this weekend.
Thanks for all your help and support.
PERFORMANCE
Max. b.hp 2.35 @ 14,418rpm (open exhaust/5% nitro)
2.34 @ 11,670rpm (Bolly pipe @ 480 mm/5% nitro)
2.03 @ 8,891rpm (Genesis pipe @ 510 mm/5% nitro)
1.97 @ 12,768rpm (SuperTigre Quiet Muffler/5% nitro)
Max. Torque 231 @ 7,813rpm (Genesis pipe @ 510 mm)
229 @ 9,000rpm (Bolly pipe @ 480 mm)
220 @ 7,300rpm (open exhaust)
186 @ 5,923rpm (SuperTigre quiet muffler)
ID:	1132569   Click image for larger version
ID:	1132570   Click image for larger version
ID:	1132571   Click image for larger version
ID:	1132572   Click image for larger version
ID:	1132573   Click image for larger version
ID:	1132574   Click image for larger version
ID:	1132575   Click image for larger version
ID:	1132577   Click image for larger version
ID:	1132578   Click image for larger version
