ORIGINAL: petec
If you have anything building up on the plunger it could cause it to stick. Can you clean the pink stuff off and see if it clears up the issue?
I cleaned the pink stuf off everything and sprayed all parts with carb cleaner. It started right up and I retuned.
I'll wait a few days and see what happens at the field. If that clears it up I think I'll install a new plunger and diaphragm that I just ordered.
Gator
