RCU Forums - View Single Post - Phoenix Extra 330S 60-90 Size
Old 02-11-2009 | 08:12 AM
  #597
cmoulder
Default RE: Phoenix Extra 330S 60-90 Size
ORIGINAL: JackMcAfee
Am confused about your pictures
The picture of the cowl with the Saito 100 installed appears that the position of th engine
is somewhere between 180 to 270 degrees - not 270 as you mentioned
Can you enlighten me on this
Jack, I don't know if you saw it yet, but there are some more pics below the post you replied to, [link=http://www.rcuniverse.com/forum/fb.asp?m=7002907]HERE![/link]
This shows the engine mounted using the factory-supplied engine mount using the pre-drilled firewall holes.
