RCU Forums - View Single Post - Did I Do Something Wrong....
Old 02-11-2009 | 04:14 PM
-pkh-'s Avatar
-pkh-
Default RE: Did I Do Something Wrong....
The cigarette lighter plug will probably put out enough Amps for your charger (probably good for 20A+), although the "auxiliary" sockets in some vehicles are only fused for ~10A (they're not meant for a cig lighter, just 12VDC accessories). Most vehicles switch the power to the sockets off with the ignition/accessory switch, so you may have to leave your keys in the car to keep the sockets powered up.
As mentioned above, be sure to have a safe surface to put the batteries & charger on in case they overheat, puff, or catch fire. It would be best to have everthing outside the vehicle, on the ground or other safe surface.
