exi 450 LE
purchased an exi450 LE from you, what motor is being used in this copter? the 3800kv and the 4200kv outrunner motors that i have, will not work in this copter as they are to wide. the inside dimension of the frame is 22mms and the motors are 28 mm in diameter....thanks for the help
