RE: Help with Extra 300S
Very good instructions. As designed the plane is set up very well and will work fine. If you use the rudder a lot you may want to install a pull/pull system instead of the single rod they have. I fly a lot of old turn around pattern just for fun and do a lot of knife edge flying so I like all the strength I can get on the rudder but for general flying the set up shown is pretty good and very easy to set up. Very impressive plane and they did a lot of thinking in the design and set up.
