RCU Forums - View Single Post - Temperature gauges
Old 02-12-2009 | 02:43 AM
Gex_61's Avatar
Gex_61
Default RE: Temperature gauges
The probe is at the end of the loop of wire. You simply wrap it around whatever it is you want to temp, and pull it tight using fuel tubing or a zip tie. I've used it on nitro engines and electric motors. It does not need to be attached to the glow plug.
For $15 it is good quality, and it seems to be as accurate as any other temp guage. We have compaired the readings against several other temp guages, including the Duratrax guage and those overkill expensive guages people have had at the track.
