RCU Forums - View Single Post - buggy engine to flex shaft help plz
Old 02-13-2009 | 12:23 AM
Ron Olson's Avatar
Ron Olson
Default RE: buggy engine to flex shaft help plz
Hopefully I got to you before it's too late. You might have a problem with the 5mm unthreaded collet as it has to be tight against the flywheel. I'm worried that it may make the flywheel slip if it isn't. You'll find out quickly when you try to start it using a hand-held starter.
