RE: buggy engine to flex shaft help plz
i did not buy anything yet, i was going to use the nut that holds the flywheel on the buggy to hold the boat flywheel on, then but the collet up to that. also the engine is fitted with a pull start. the reason i was going for the unthreaded collet was because i did not want to cut the sg shaft down, in case i want to put the engine back in the buggy
