ORIGINAL: chopper man
ORIGINAL: Gray Beard
If you don't have a line and clunck on that third line removing fuel will be a problem. I use dots myself but have tried doing it like John has his, very simple and something even I can't mess up.
Well I didn't think about defueling[>:] This tank has 3 ports with only 1 line with a clunk on it. So I put the pressure line on the top nippple and the fill on the middle. I hope thats going to work. Well I guess I'll just have to turn the plane upside down to defuel. Just when you think you've got this hobby figured out things go the other way. I'm really tired of messing with this plane so I'm just leaving things the way they are and hope to just get it finished up so I can put her in the air for the first time. I finished the actual build almost 2 years ago but I never finished putting the radio in or that nitt picking stuff. I might be able to finish it this weekend and fly Sunday.
chopper
If you use that external tubing holder from world models from the previous posts, you can run your fuel feed line through it and use it as a filler and a clunked defueller line.
