RCU Forums - View Single Post - EXTRA 300S 60 115.99
Old 02-13-2009 | 09:38 PM
mclina's Avatar
mclina
Default RE: EXTRA 300S 60 115.99
ORIGINAL: bjor
ORIGINAL: mclina
Looks like a Nitro Models plane.
How do you figure that? Ones 54" and the other 64".
Actually, they both have 64" wingspans. One of them just lists the fuselage length in the title.
Toy Sonics:
 Wing Span: 64in/1630mm
 Wing Area: 46 sq dm
 Flying Weight: 6.8lbs/3100g
 Length: 55in/1400mm
 Engine Required: 2C 0.60 cu in; 4C 0.91 cu in
 Radio Required: 4 Channels, 5 Servos
Nitro Models:
Fuselage length: 54 in / 1370 mm
Wing span: 63.8 in / 1620mm Engine Required: 2c 0.61-0.75 cu in
Wing area: 705sq in /45.5 sq dm 4c 0.91 cu in
Flying weight: 6.5 lb / 2950g Radio Required: 4 channels,5 servos
I was mainly commenting on the apparent similarity in build and hardware quality between the two, not to mention the identical price.
