 EXTRA 300S 60 115.99 >
Old 02-13-2009 | 01:08 PM
flystright's Avatar
My Feedback: (13)
Default EXTRA 300S 60 115.99
Hi. If your looking for a good price on a Extra 300s 60. I found this plane on sale it is a good looking plane. I found this plane while searching the internet looking for info for the extra 300s. Here the link to this plane. http://www.toysonics.com/extra-300s-...plane-arf.html Its only $115.99 a good buy. Just wonted to share.
Old 02-13-2009 | 01:17 PM
mclina's Avatar
Default RE: EXTRA 300S 60 115.99
Looks like a Nitro Models plane.
http://www.nitroplanes.com/ex306054niga.html
They can be good planes for the money, but you definitely want to replace a lot of the hardware and you better be able to build it without much help from the instruction manual.
Old 02-13-2009 | 07:26 PM
bjor's Avatar
ORIGINAL: mclina
How do you figure that? Ones 54" and the other 64".
Old 02-13-2009 | 09:38 PM
mclina's Avatar
ORIGINAL: bjor
ORIGINAL: mclina
Actually, they both have 64" wingspans. One of them just lists the fuselage length in the title.
Toy Sonics:
ï‚§ Wing Span: 64in/1630mm
ï‚§ Wing Area: 46 sq dm
ï‚§ Flying Weight: 6.8lbs/3100g
ï‚§ Length: 55in/1400mm
ï‚§ Engine Required: 2C 0.60 cu in; 4C 0.91 cu in
ï‚§ Radio Required: 4 Channels, 5 Servos
Nitro Models:
Fuselage length: 54 in / 1370 mm
Wing span: 63.8 in / 1620mm Engine Required: 2c 0.61-0.75 cu in
Wing area: 705sq in /45.5 sq dm 4c 0.91 cu in
Flying weight: 6.5 lb / 2950g Radio Required: 4 channels,5 servos
I was mainly commenting on the apparent similarity in build and hardware quality between the two, not to mention the identical price.
Old 02-14-2009 | 11:14 AM
carrellh's Avatar
Toysonics and Nitromodels do not make the planes.
They just import and sell the stuff. It is very possible that they buy product from the same manufacturers.
The fact that toysonics uses the description "remote-nitro-gas" and nitromodels also uses it could lead one to believe that they buy their ad copy from the same place or that they may be connected in some way.
