ORIGINAL: Sugafree
http://www.horizonhobby.com/Articles...ArticleID=1318
Car Fuel Facts
If you read the R/C car magazines, engine instruction manuals or talk to local racers, you'll likely find conflicting information about car fuels. The main controversy seems to focus on how much and what type of oil is needed for a car fuel.
Here the straight scoop based on over 15 years of experience that includes working closely with engine manufactures, industry experts, top-level racers and the results of testing literally hundreds of formulas in all types of car engines and conditions.
Why Not Airplane Fuel
Car engines operate in a totally different environment than do airplane engines. Airplane engines spend a great deal of their running life at full rpm, they have a constant airflow from the prop to aid in cooling and instant throttle response and acceleration is not as critical as with a car engine.
Car engines spend most of their life accelerating from one corner to the next and are seldom at full RPM for more than a few seconds. They rely on an oversize heat sink head to dissipate combustion heat and racers actually tune car engines based on throttle response.
Fuel designed for airplanes typically have from 15 to 20% oil. While the manufactures that truly understand the requirements of car engines typically put 8 to 12% oil in their car fuel.
Why 8% to 12% Oil
Using high oil content fuels (above 15%) in gas car engines won't provide improved engine life, as some would expect. Through extensive testing we've discovered the point of diminishing return as far as oil content to engine life is actually around 8% for most car engines. In other words any more oil than 8% in the fuel does noting to improve the life of a car engine. In fact the secondary effects of high oil content fuels can actually cause engine damage by encouraging over lean runs. Here's how.
Using high oil content fuel causes a car engine to be unresponsive during acceleration acting as if the engine were running rich. Typically when using high oil content fuel, in order to get crisp acceleration and response, an engine will need to be adjusted overly lean. In addition the high oil content prevents lean bog when an engine is over-leaned thus allowing the engine to run at this lean setting without the customary telltale lean bog warning letting you know the engine is overheating.
In summary, high oil content fuels don't give added protection. The point of diminishing return from a protection standpoint in a gas car application is about 8% oil depending on the oil type and engine. Anymore oil than this doesn't offer added protection and has potential secondary effects that reduce performance and can actually cause you to over lean your engine in an attempt to get crisp throttle response and acceleration. Do yourself a favor and follow these two rules:
Rule #1- Always use a high quality fresh fuel designed specifically for gas car use that has between 8% and 12% oil preferably with at least some castor in it. (We recommend Blue Thunder Sport or Race Formula)
Rule #2 - Don't use airplane fuels or any other type of fuels that have over 15% oil in your gas car engine.
Yeah that was basically what i meant but obviously your explanation is better, Ill just stick with well known brands. BUT back to the point of this forum, no it shouldn't harm your engine.
