RE: fox eagle 60
With Fox always start by opening up the high speed needle one full turn. then set the low speed, after that is set then tune the high speed. If you try it the other way the engine will never tune. Now the down side, if the weather changes from Sat to Sun. you have to do it all over again. Also you may need to add caster to your fuel. Fox engines were made to run on 20% caster
