RE: DL-50 engine
Have you set the carb needle setting to factory. If so and you are still fluding the engine there may be trash in the carb. The thing you describe about carb noise is strange and I had that sound once and it was the reed block. It Had a metal something under it and was letting crank case pressure come back through the carb.
