ORIGINAL: twomanytoys
You dont have to do aanything to the fuel tank. Just take the glow plug out, turn upside down and crank it over for a few seconds. Install plug then fire it up.
If you do that you will sometimes continue the flooded condition because the fuel can flow from the tank through the carb by gravity. I usually just pinch the fuel line to the carb before turning it over and spinning the engine.
