ORIGINAL: basman
Can anyone give me dimensions? back plale to prop hub / o/a height / o/a width
From back of stock standoff to prop hub face is 170mm or 102mm without standoffs (to back of mounting lugs)
From mounting bolt at back of carby to prop face is 165mm
Overall width at head = 80mm (no muffler fitted)
Overall width at outside of mounting lugs = 97mm
Overall width at side of crankcase = 70mm
Overall height = 163mm from bottom of crank to top of head, ( add 15mm with plug & plug cap fitted)
If you need others dimensions let me know
Cheers
Scott
DL Engines AU
