RE: GMS 2000 47 won't run
It is possible that the tank is a little low, you could have a small air leak, will it run back if the throttle is fully closed? As long as you get it running and it keeps going you'll be fine though. How much lead did you need to add to the nose to get that plane to balance?, i know my explorer .40 had a 32oz 21cc weedeater engine on it and the CG came out perfect.
