RCU Forums - View Single Post - Comp ARF Flash update
Old 02-17-2009 | 01:18 AM
  #755
digitech
My Feedback: (10)
Default RE: Comp ARF Flash update
ORIGINAL: Grodus
Hello, I have a few questions for all you Flash builders/drivers.
I am looking for an airframe for my new Rabbit. I have a set of Behotec c-36 retracts that I am not currently using. Since my are the spring down version, would they be acceptable to use in the Flash? I used these units on a Falcon 120 and I did have the nose gear fail to lock down on a couple of occassions against the airflow. However, the valve I was using slowly bled the pressure side during extension rather than dumped the pressure. I think by using an Airpower valve I can get the gear to come down with more authority and lock consistantly. Also, I have Behotec struts, wheels and brakes. The tires are fixed with screws thru the hubs and I dont see the tires coming off as has been reprted here with the Intairico tires. Has anyone used the behotec wheels and brakes on this airframe and are they not compatable for some reason?
Lastly, my complete engine install weight is 3.4lbs and is reported to make 20+lbs of thrust. I havent tested or even started mine. Would this be a good engine for the Flash?
Thank you,
Cody
you will always have that problem that the front gear is not locking properly.
i would suggest you lose the front LG cover to get rid of some of those problems
