RCU Forums - View Single Post - Cheap and Simple ideas that work
Old 02-17-2009 | 11:06 AM
bigbri
My Feedback: (287)
Default RE: Cheap and Simple ideas that work
After my expensive electronic brake valve failed I was looking for a more reasonable alternative. I have switched to these valves and lube the wheel brakes lightly with silicone grease. Works awesome! re-lube brakes about every 30 flights or so Works just like ABS braking....14.95 vs about 100 dollars....85 dollars saved on each jet!!!
Robart 186 One-Way Air Control Valve
