Need help with ARF modification
Tony :
You probably already have it your parts bin. Use 4-40 push rod.
It can be bent close enough to parallel then tweak as needed. I
like to position one of the arms of the rod so that it is sandwiched
by the control horns screws.
The other way to go would be the hobby shop music wire size
3/ 32" or .090 dia.
