RE: battery for 26cc engine
A 600 mah battery should give you about 4 - 5, 10-12 min. flights if it's a good battery. I recommend 4.8v, 1200 mah or bigger to to prevent having to recharge during a day of flying. The more RPM you are running during your flying, the more battery you will use.
