RCU Forums - View Single Post - A problem with the Wren turbine position
Old 02-18-2009 | 03:10 AM
bandit_av
Default A problem with the Wren turbine position
Hi
I have the Wren SS and and I have a big Problem with installing it, because the only way I can do that is
putting the turbine in position that the plug is nearly at 7-8 o'clock and not in the regular position like 10 o'clock position.
Is there any problem with that I should expect?
Will the turbine run good?
Thank you
Avi
