RCU Forums - View Single Post - A problem with the Wren turbine position
Old 02-18-2009 | 05:38 AM
Jim Cattanach's Avatar
Jim Cattanach
Default RE: A problem with the Wren turbine position
The position of the glow plug in the Wren Supersport should be at the 2 o'clock position. Wren say this is required to ensure a proper flow of fuel to the bearings.
Sara from Wren will probably chip in with a solution, if this is not possible.
