RCU Forums - View Single Post - rudder push rod bows
Old 02-18-2009 | 08:28 AM
Skarn
Default RE: rudder push rod bows
Payne,
In head hold mode, the gyro's don't act like you think they should on the ground....you'll get full servo deflection before your stick moves all the way.... it will stick to one side, etc. Put it in rate mode and you'll get the "normal" servo movement.
Also are you using the round servo horn?
Skarn
