RCU Forums - View Single Post - sv27 lipo setup..will this work? double run time
Old 02-18-2009 | 06:47 PM
SV27dayton's Avatar
SV27dayton
Default RE: sv27 lipo setup..will this work? double run time
With certain "hot setups" things can get pretty warm. Since you are runnig the bats in parallel this will be easier on them. So if your motor and ESC can hadle your setup you should be OK. That would solve the too light with lipos problem the SV often has too. Pretty pricy setup but hey, the good ones are.
