Go Back  RCU Forums > RC Boats > Speed - Electric
 sv27 lipo setup..will this work? double run time >
Speed - Electric For all your electric boating needs.
Old 02-15-2009 | 01:58 PM
Default sv27 lipo setup..will this work? double run time
im running (2) 5000 mah 2s1p 20c lipo and can i add 2 more lipo to get more run time and wire in parallel? so basically these parts all in my Supervee27. I get about 8 min runtime now. that should get it to 16-20 mins. and do you guys see any problem with the motor? can it handle it?
(4) 5000 mah so it will turn to 2s2p
(2) these connectors
Old 02-18-2009 | 06:16 PM
Default RE: sv27 lipo setup..will this work? double run time
This looks better to me. A lot less clutter...
http://www3.towerhobbies.com/cgi-bin...?&I=LXNKY8&P=7
Old 02-18-2009 | 06:47 PM
SV27dayton's Avatar
With certain "hot setups" things can get pretty warm. Since you are runnig the bats in parallel this will be easier on them. So if your motor and ESC can hadle your setup you should be OK. That would solve the too light with lipos problem the SV often has too. Pretty pricy setup but hey, the good ones are.
