RE: The Unofficial all things Jet drive thread
the reson i ask is your useing nicd battery or bricks as i call them . for go resolts in speed and runtime you wont it as light as you can get it . but i thank your pretty good i try to keep my boats around 5lb with this drive . but even if your a little over you have the larger motor to make up for it . see i wont this boat to be equaly fast as big blue was on 4s . but since this hull is shorter and the 3 blade impeller i have i thank i mite blow the deck off of blue
