G45 Spinner?
Not an issue...The G45 comes with 2 prop bolts, one longer and tapped for a spinner bolt..You will have to re tap for a 10-32 if you get a Tru-Turn spinner..Any spinner will work...The Mejzlik props I have are already drilled for the 10mm bolt.....
