G45 Spinner?
Old 06-10-2003 | 06:42 AM
Default G45 Spinner?
Hi all,
I'm putting a G45 with a Mejlik (whatever!) 20x10 into a CM Pro Giles 202. Should hover at half throttle!
The cowl is 70mm across the spinner circle.
No-one here in Australia can source me a spinner! I know they have to be out there. The issue apparently is getting the right prop nut.
Who makes spinners to suit Zenoah?
TIA,
Kendo.
Old 06-10-2003 | 12:30 PM
Antique's Avatar
Not an issue...The G45 comes with 2 prop bolts, one longer and tapped for a spinner bolt..You will have to re tap for a 10-32 if you get a Tru-Turn spinner..Any spinner will work...The Mejzlik props I have are already drilled for the 10mm bolt.....
