RCU Forums - View Single Post - Upset with flyrcrivesud.com
Old 02-21-2009 | 04:07 PM
06sportster's Avatar
06sportster
My Feedback: (7)
Default RE: Upset with flyrcrivesud.com
ORIGINAL: sonat
we do not offer lamav4 parts with plastic busing and eflite upper swasplate to try to do some fitting like other do
we manufacture real upgrade
the lower rotor head we have redesign, ( new plastic ) it is crash resistant and very low weight
this part solve that issue
primary function of our company
more flight time and crash resistant parts as best as possible
beauty is not our priority
aluminum parts have to much issue for this micro heli,
it is not a t-rex or a blade 400 that you can add weight like you want
p.s. stiff blade when you do quick movement make the heli crash so other parts will break you may not break the blade but something else will
you need a little of flex in them
we are on the now on the 8 generation of our racing blades
www.flyrcrivesud.com
I am not bad mouthing your products or anything. I knew the reason why they are the way they are. I was just upset with the fact that I called you and asked if your blade grips would work with the E-flite aluminum heads. You told me that they would, but I would have to win your auction on ebay to get just the blade grips.
I have had the E-flite lower aluminum head for some time now, and do not wish to get rid of it. I have had zero problems with it on and would like to keep it since I have already spent the money. The main reason I contacted you was I wanted the lightest blade grips to go with my current setup.
Do you make a link that will work with your grips and the stock style lower hub?
