RCU Forums - View Single Post - Comp ARF Flash update
Old 02-22-2009 | 03:45 PM
  #766
KC36330
Default RE: Comp ARF Flash update
you should get a hard down and lock with any decent air pressure unless you've got a restriction in the air flow or binding in the retract or its travel. if they are spring down, you may need a stronger spring.
