RCU Forums - View Single Post - help with servos
Old 02-23-2009 | 01:17 PM
xt2nitro
Default RE: help with servos
The likely reason could be that you have not set the end points on your throttle servo correctly using your transmitter this could lead to the servo trying to open/shut the carb more than the carb can actually move, which burns out the servo. I have gone through the same problem.
