RE: Need help programming radio and Tiger 1
Whew! Thanks for pointing out the RX connections. For mine, to get it to work per the Tamiya instructions, I had to switch the ELEV and AIL. The rudder and throttle were okay. the only thing left is the machine gun. I've not quite figured out how to set it. The above instructions about setting the vertical trim. I'm sorry, but I'm not sure which switch that is.
But all in all, its working pretty good! That main gun is impressive, the flash and all! The only thing is when I weathered the main gun it wasn't fully extended so bare "white wash" ring was showing. I've started fixing that. All that's left now are the detail. The basic tank is done!
I'll take some pics, its done in Winter Camo, Spring... so its white is faded....
Thanks again for all the help!
