RCU Forums - View Single Post - Futaba TX and JR RX compatibility?
Old 02-24-2009 | 05:33 PM
bruce88123
Default RE: Futaba TX and JR RX compatibility?
Mike is correct. Basically, one uses what is called "Positive shift" while the other uses "Negative shift". This is the direction the carrier frequency is shifted when transmitting. No amount of crystal swapping will help. Swap in a Futaba RX or one from an aftermarket supplier that is compatible.
