RCU Forums - View Single Post - Throttle setup help
Old 02-24-2009 | 07:05 PM
Broken Wings's Avatar
Broken Wings
My Feedback: (20)
Default RE: Throttle setup help
ORIGINAL: crabby62
I am working on a Big Stick 60 ,arf. When I fitted up a OS FS90, I saw the throttle lever is on the left. I dropped a 60 2 stroke there and saw a rh throttle. The plane is setup for rh operation. How would I run a lh throttle on this plane? I wonder if I have to use a flex cable to accomplish this. I sure want to use a 4 stroke. Thanks for any info.
You're going to have a blast with that model. I've got one and it flys great.
You could just leave the original grey tube in there and if you every wanted to switch engines the throttle tube would be there for you to use.
ID:	1144124   Click image for larger version
