RCU Forums - View Single Post - SPE26CC Sputtering
Old 02-25-2009 | 09:34 PM
jedijody's Avatar
jedijody
Default RE: SPE26CC Sputtering
If you have an RcExel ignition on the engine already just check the timing and adjust it to 28 degrees. Check your plug gap also, should be .020-.024". If that doesn't take care of it try a new spark plug. Here is the RcXel instruction manual that will show you how to set or check your timing.
http://www.cncengines.com/rcexelcdi.pdf
