RE: Throttle setup help
Crab, here is a little hint, when you bend the rod 180 degrees make the end you're connecting to the carb end up slightly below the hole in the throttle arm when the throttle arm is straight up and down. That way the rod won't have to flex so much as the arm travels through its arc and the hole position is lower at the end of the travel arc.
